Connect external DAC to RS250 options
What do you mean by; “does not recognize”?
Any dac should handle the coax output of the RS250.
Did you set output to coax under the ‘in/output settings’?
And did you limit the output clockrate to 48kHz?
The input chip is a rather old CS8412 that cannot handle high-res. If you don’t downsample it will go on tilt. It will give weird noises or mute altogether.
In my opinion you’d rather just use the analog out of the Rose since that is probably better and supports a lot more features (like high res files, DSD, parametric equaliser.
The 8412 is an anachronism. The pcm63 are old R2R iirc. That dac design is 30 years old. There has been incredible progress in DACs even in the last decade, let alone 3 decades.
I have a modern discrete R2R dac but the internal dac of the RS250 is not much worse. That Theta might be built for eternity, but IMHO only as a boat anchor.
Thanks for the reply… the Theta will flash on a blue LED when the source is connected. It worked with the Rose for a few weeks and then stopped, and actually started up again for like 5 minutes and then disconnected from the source again. CD player connects and functions with no issue but w the streamer its touchy at best. So I’m not sure if it’s a under power or over power issue thought there might be some matching issues when it comes to older equipment.
I will say, the quality of sound with the Theta is vastly superior to what the native DAC on the Rose produces. The Theta has Burr Brown PCM63k chips. But yes, the weight would be admired by most boat anchors-- lol.
For sure there are some great new DACs and ultimately I’ll go in one of those directions but have had this Theta and Bryston Amp/PreAmp set up for about 30 years and hate to bin it as the system still does a good job— nostalgia-- lol.
Ahhhh!!! Figured out the issue…the Theta will play albums from the Rose (via Tidal) up to 16 bits, 44.1khz but when I play a track at 24 bits,96khz the Theta is unable to process.
lol— now more reason to upgrade.
Just as a note-- at the 16bit, this Theta is quite good when compared to the 250s internal DAC. The internal DAC has ZERO soundstage and while I have heard new internal DACs that are better than the Theta (everSolo A8 in example), it is well worth being operational when my other choice is only the internal— Which R2R dac are you running?
I told you what the issue is. The input chip cs8412 can handle only cd quality. No high resolution.
A dac is much more than just a dac-chip. And while the old BB multibit chips are highly regarded they are outdated in the world of high-res streaming. And while the power supply is probably very good, the in and output filters and connections are getting museum worthy. As is the knowledge of the time with which they were made.
I have done lots of modifications on my cd-player and a bunch of DACs. I still have a bunch of old cd-players but they are pretty much useless. Unless as a boat anchor… One of them is a Philips with a famous DAC chip in it, the tda1541. And I have (sold) a lot of Tda1543 DAC with modifications on the output that actually can handle 24-96. I recently brought one for buying and auditioning speakers. Incomparable with the old Philips cd-player. That is like watching a old CRT colour TV compared to a modern 4k flatscreen.
I have done a lot of forum discussions on R2R DACs and a lot of comparisons with people coming over or meetings at others homes. And I do remember how ‘good’ high end cd-players sound. And they nearly would have killed my audio hobby if I didn’t have a great vinyl setup. Which has always sounded better and more engaging. I’ve upgraded my turntable as well and it’s still my reference but digital has upgraded so much over the last years with discrete R2R DACs that it comes ever closer.
I am now using the Rose RS250 internal dac because I am trying out new monoblocks on Magnepans. My regular system has signals going via USB to the Denafrips Ares II dac, to a Gato amp 150 to my own design 1,5 way bipole (2 Ti 3" fullrange + AMT supertweeter) design plus Genesis VI for subwoofers. Yes, I love those Genesis giants from the 90-ies but they have an overcomplicated crossover.
I am now saving to replace the Denafrips Ares II. It’s very good but it was all I could afford a few years ago. It sounds very open and deep. Wide but not like some. Details are all present but not accentuated, a bit like chocolate sirup. If I play DSD on it, it sounds amazing. Only it lacks i²s input and I can’t or won’t modify it.
I was saving for a Venus 12th but now there is a new brand with a new R2R dac called Laiv Harmony. That ticks a lot of boxes and if I read and saw the reviews, is even better.
If the RS250 sounds flat in your setup there is something wrong. The Eversolo D8 has a very similar internal dac. And I do hear soundstage and depth. It might be some setting or cables or whatever. It is a very good dac on itself. However, I prefer the natural sound of an R2R dac, and the signal from the RS250 is good enough for much higher priced DACs.
Jeep,
I have the LAiV Dac. You won’t be disappointed if you go for it.
There’s a lot of visual bling in its design which I equate to fancy paintings in a restaurant.
I go for the food not the decor.
The sound quality is superb.
I have a Gustard r26 r2r Dac for sale now.
Design is an art. A little bit of restrained extravaganza is all in good taste. Like my Italian Gold Note phono has a beautiful cnc-milled case with a gold badge with their logo (Etruscan Horn) on it. The Laiv is close match (but for the spikes).
Denafrips seems unable to decide on one universal look. As a designer that irritates me to no end. The frugal amount of usability is a solid choice. No remote, no screen. But I miss them.
Holo sort of sticks to one look with the orange cheeks but they are so BIG. And expensive, with a high snake oil content. Now I don’t really think it’s snake oil but silver does jack up the price.
So, yes, Laiv Harmony is a lot of money but you get a lot more than what you pay for with others.
Jeep,
Yes, you do get more than than you pay for with others. I totally agree. This is a startup so a valid caveat would be can they scale up and make money to keep going. I bet that they will despite the fact that a majority of startups fail. I’ve had the LAiV Harmony for about a week now and so far it’s rock solid. Build quality is ridiculously good. With the normal distributor markup this is a $10k Dac.
It’s a little surprising that there’s no internet connection for upgrades and you can’t switch inputs with the remote.
Jeep,
I was wrong on both items in the second paragraph. You CAN upgrade through a USB port just not over the internet. Secondly you Can switch inputs remotely! I have no quibbles. Support response was overnight on both issues. They are very quick to respond to questions.
Lol. I was surprised it wouldn’t switch inputs, that’s the first most important function.
I think we better discuss in the seperate Laiv topic and not here.
I also discuss this a with a lot of ppl on head-fi.org. lots of knowledge there. Weng Fai is present too.
LAiV Harmony R2R DAC Impression and Reviews | Page 9 | Headphone Reviews and Discussion - Head-Fi.org
Given the price of both the Rose and the Laiv this is a very sensible choice. Only for i²s input you will need to get some kind of DDC like Nobsound (Douk) U2pro of Denafrips Iris etc. as a possible upgrade.
@Jeep , curious why a DDC would be needed if you are going direct i2s from the RS130 direct to the Laiv DAC. I am really asking because I often wondered if there was a benefit in having a DDC even if a direct i2s connection was possible.
Duffer 5,
I’m with you. I2S Rose RS 130 to I2S LAiV works for me without a D2D converter.
This topic is called DAC to RS250 and the RS250 doesn’t have an i²s output. I have the RS250 so I was merely speaking for myself and others who drop in when they see the title.
But to answer the question of why an external DDC. Yes, it does improve sound quality. And so does adding an external worldclock to that DDC. The digital signal over cables never look perfectly square and with perfect length (timing). This can cause errors. A DDC cleans up the signal.
Jeep,
The LAiV has two internal crystal clocks to clean up those signals. Is this enough?
In all honesty, I didn’t try it so I can’t tell from experience. And I probably won’t any time soon.
Because I have the same dilemma; what is more important, what is the best solution a better dac with better clocks, galvanic isolation etc, or a cheaper model with a seperate DDC.
Someone who has a lot of knowledge on this topic is Hans Beekhuizen. He explains it on his YouTube channel and website.
I do know i²s is the best connection. So for the RS250 it wouldn’t be a waste of money to get a DDC that is not crazy expensive. Because you add the i²s function. But if I had the RS150 I would just stick to the best dac. Because many people who say it makes such a ‘big difference’ mostly use a computer. So how that compares to a dedicated streamer with i²s? I have serious doubts. Also I really like to cut down on the number of boxes.
