Hi ROSELOA,
I did the experiment during weekend, experimented with Pre Out Level Setting of different values and each time I changed the value I did press the APPLY button on the top right corner of the screen. Below are my results:
Source: TIDAL Eagles - The Long Run MQA 192 kHz, play volume = 68
Pre Out Setting value (balanced) = 100 mV, NO cracking noise was heard.
Pre Out Setting value (balanced) = 200 mV, NO cracking noise was heard.
Pre Out Setting value (balanced) = 300 mV, NO cracking noise was heard.
Pre Out Setting value (balanced) = 400 mV, CRACKING NOISE WAS HEARD.
Pre Out Setting value (balanced) = 500 mV, CRACKING NOISE WAS HEARD.
Pre out Setting value (balanced) = 1000 mV, CRACKING NOISE WAS HEARD.
Pre Out Setting value (balanced) = 2000 mV, CRACKING NOISE WAS HEARD.
I did not try 3000 mV, 4000 mV and 5000 mV because the play volume was too loud.
As control experiment, I also did the following tests:
Source: TIDAL Ealges - The Long Run MQA 192kHz
Without Pre Out Level (i.e. OFF and APPLY), the cracking noise was heard at play volume 50.
Source: NAIM CD5XS, CD Pink Martini Sympathique, track 5 La Soledad
Without Pre Out Level (i.e. OFF and APPLY), the cracking noise was heard at the piano solo portion with play volume 48.
Also, I got additional inputs from Kinki Studio technical support, they said their XLR inputs (for EX-M7 Power Amp) are single-ended design. I am connecting RS150 to EX-M7 by a pair of XLR cables.
ROSELOA, what is your assessment with these information? I appreciate if you may suggest the next step. Thanks!
Thomas
