What is the RS151 screen resolution?
What is the RS151 screen dimension so I can create my own custom backgrounds for fit the screen perfectly. Thank you.
@reisanchez
The screen resolution of the RS151 is 1920 × 382 pixels.
If you would like your custom backgrounds to fit perfectly, we recommend creating images in this resolution for the best results.
If you need any further information or assistance, feel free to ask anytime.
