Ha Hendry,
Dat is balen, maar ze sturen vast een nieuwe op. Je hebt toch wel een zekering met de goede specificaties gekregen? Het zou moeten werken als de zekering niet kapot is. Bij mij ging het probleemloos. Hou me op de hoogte!
Ha Hendry,
A fuse isnât change only with sound on your system. But it should be called an upgrade, everything was being improved, like details, the width & depth, more engaging with much better presentation, just like you upgrade your cable.
That is the case same as asking why you donât use the stock âblack & whiteâ cable before changing them to a more high end one.
For me I would regarded it as a media/way to extend the potential of your device to a much better level.
Hallo Hans,
Ik heb opnieuw bij een andere leverancier de purple fuse besteld en deze werkt wel. En hoe
Ongelofelijk wat een verschil. Had dit niet verwacht
Groet,
Hendry
I know⌠maybe you could share your experience in English and run for incoming shells.
Glad you like the fuse!
Today, I received the purple fuse for my RS250A. I too was skeptical at first, but holy fuse, what a difference in sound quality. Very happy Iâve tried it.
You should be able to distinguish within some secondsđ Purple fuse is the best C/P among all!
Other than that you may need to spend nearly a double or more!
Enjoy!
I own the RS250, I would like to try with this famous fuse, do you have a place, a shop, a link where to buy it?
Is it the same fuse as the RS250A?
Thank you and have a good day.
I forgot the value of the fuse. But I have numerous SR fuse including Blue/Orange/ Purple etc⌠Let see if I could mail you one with the correct rating
Slow blown, right?
Yes. Let us know of your experience.
By no mean to dampen the enthusiasm of changing fuse, and I do agree that it has various degrees of impact (could be negative too) over sound quality since I have a few replacements in my gears as well.
But do note that when a fuse is burned. The loss is irrecoverable. It âhurtsâ when it is expensive.
This happened to my RS150B a month ago. The fuse burned for unknown reason during a system reset. I replaced the burned one with the spare fuse in the machine. It burned immediately as well.
I took the machine to local distributor for repair. Certain electronic parts were replaced accordingly.
The machine is up and running now, but not the replacement fuse.
Surely this faulty situation wonât happen regularly. But when it does, be prepared that the loss of the fuse is irrecoverable.
Hi everyone,
I have read this topic with a lot of interest.
I looked at the back of my RS520 and find a circuit breaker with the text âpress to resetâ.
Does this mean that there is no physical fuse in there?
If so I cannot replace the fuse and cannot change over to Purple Fuse.
Is this correct or is there another way?
You are correct. There is no fuse you can change for your RS520.
Guys, if you donât feel the clear difference when you reverse the same fuse, regardless of brand and model, it means that your system is far from the truth. This must be felt, regardless of whether you have acoustic treatment in the room or not.
What about holding the fuse in front of the device? Maybe taping it to the power button? Will 4 fuses, taped in each corner make even more difference? Would the effect be cancelled if thei are pointing in different directions?
It seems to me that you have to be respectful of others.
What is the purpose of bothering a person, who has good will and predisposition to share knowledge?
There is a difference, and not even particularly subtle one, between knowledge and complete and utter BS that violates all known laws of physics.
