@ROSEHAN Can you let me know if the attenuation switch in any way degrades the sound/performance of the 180?
I would like to activate and use more of the volume control. With my current streamer/DAC, I’m only able to turn up the 180 a couple of notches until it is too loud. I haven’t been able to successfully use the bypass option on the 180 either.
Thx.
