I performed a factory reset and am unable to re-register my 250 A and unable to use it.
Please help us by checking the following points:
- What do you mean by being unable to re-register your RS250A after performing a factory reset?
Please provide more detailed information about the issue. - When using the RS250A, do you see a message indicating that the device is not registered?
If so, please try the following steps:
RS250A → Settings → Device Management → RS250A → Register
If the device is already registered, the option should display “Unregister.”
