On occasion after a successful rip fields are not cleared for the next rip. The only way I have found to clear the fields from the previous rip is to reboot the RS-151 Which is extremely unsatisfactory if you are listening to music/playlist whist ripping a collection. This has happened several times….
Thank you for your continued support.
@ROSEHAN @Rose_love
@DEFSKI66
"Could you share your Rose ID and version from Settings > System Info? We will check it for you."
ROSE ID 107AF4
System Version 5.11 (official)
Note. This appears to happen when ripping is complete and the process returns to the rose home display. Returning to cd ripping and the fields are still complete with the last ripped cd. Ejecting the cd does not clear the fields…
"As you mentioned, we tested ripping 5 CDs while playing Tidal audio, but were unable to reproduce the issue or find any abnormalities.
If you could provide a consistent reproduction scenario or send a video recording of the issue when it occurs to the email address below, we will investigate it further"
shim1691@citech.kr
There is no consistent reproduction scenario….thats the point. It only happens occasionally for some reason.
Therefore I cannot take a video every time I rip a cd just in case the scenario should occur. Sorry.
Recommend you look at the process to see what triggers the wiping of fields following a successful rip AND what might prevent that wiping from happening. As I added the process automatically returns to the Home Screen for some reason following a rip and then when you return to cd ripping you cannot clear the fields….
Please remove your reply where you have posted my email address, or edit and remove my email address. Thank you
