I have the following questions:
Is it possible for Shazaan to automatically display the cover art when using Rose Radio?
Unfortunately, it’s still not possible to arrange the radio station favorites in a custom order.
After every update, the output voltage is reset to 300mV.
After every update, the icons on the home screen are jumbled.
NO
NO
On my RS130, favorite radio stations are listed in the reverse order of their creation as favorites.
So I took this into account when sorting my favorite stations; the stations I wanted to be listed first as been created favorites last.
@Matterhorn
I will answer your question.
At this time, Rose Radio does not support automatic cover art display from Shazam.
Cover arts can only be accessed by pressing the “Search music” button at the bottom left of the radio playback screen. -
Currently, it is not possible to manually re-order radio favorites.
They are sorted by the system default.
We understand this request and have passed it to our development team for consideration in future updates. -
After the update, the pre-out level setting will change to 300mV (default).
After updating, the order of apps may change or they may not be visible.
First, access the Rose Store on your Rose device and install the apps you want to use.
To arrange apps on the home screen on your Rose device, follow the steps below:
Rose device–>Settings–>Display–>Edit Home menu
