I use the iPhone app for most interactions with my 150B. Due to changes in the app I can no longer create a playlist on Qobuz and add songs to it later. The only thing I am able to do is create a playlist of one song. Does anyone else have this problem or am I just not understanding the new changes?
Do you have playlists that you created in Qobuz APP? I will assume that you have.
Please do this first.
- RS150B > Qobuz > My collection > Settings > Synchronize
After No.1 is finished, you will see playlists that you’ve created in Rose APP.
Now, try to add songs to playlist again. You will see the playlists you’ve created before.
This is how I do it. Qobuz app first, then they show up in Rose app
