About Ambient Mode and the screen saver
First of all, thank you for your hard work. It is very gratifying to see that you consider user needs and consistently provide updates. I would like to request a few visual updates from you; I hope this is possible. Thanks in advance.
** I frequently use my 150b device in USB DAC mode. Is there any chance you could add a nice screensaver—such as a landscape or a fireplace scene—that appears on the screen instead of just the clock when it switches to DAC mode?
** If this screensaver option could also be made available during normal use, it would add a unique ambiance to the device.
@relaxv20
I have forwarded your request to our software team for review.
They will check whether this feature can be implemented. Once I receive their feedback regarding the feasibility of adding this feature, I will let you know.
Thank you for your valuable suggestion and patience.
Best regards,
Thank you very much for your interest.
