About my Rose RS520
Can I turn off my Rose’s pre-amp?
How can i connect multiple analogs to my Rose? Some help please?
Ilker
@ilkerorsal
RS520–>Settings–>Audio settings–>In/Out settings
You can enable or disable the outputs you want to use on RS520 and the outputs you do not use in the input/output settings as shown above.
Rose device does not support simultaneous output.
