- The “add to playlist” function is missing in the PC user interface.
- Also when I use the “add to playlist” function in my iPhone or iPad it puts the selected song on top of the playlist and not at the bottom. Is there a way to sort or invert the playlist?
- Is there a way to not only select “artist” but also select “Albumartist” in classification?
Hello @Querner
We are here to answer your questions.
If you look at the picture below, the icon marked in red is “Add to playlist”.
No Currently, you cannot sort or invert the list that comes out by pressing the three-dot button.
You cannot currently classify as “Albumartist”.
