Add two French cities to the weather forecast?
@ROSEHAN,
Can you add the two French cities of RENNES and REDON to the weather forecast?
@domrol
Rennes is activated on our server, but Redon is not a supported region.
If there are any other regions you would like to add besides Redon, please let me know.
If you reboot your Rose device, you can see Rennes is activated in the weather forecast.
I live between Rennes and Redon…
Just add Redon it will be fine.
@domrol
As I explained above, Redon is not a region supported by our servers.
Rennes has now been added.
