Copy the contents of a playlist into another playlist , how can I do it?
There is no way to move all the audio tracks in a playlist to another playlist at once.
When you play the audio tracks you want to add to a new playlist, they will be moved to the Queue.
Then, you can select the desired tracks from the Queue and add them to the playlist.
