Adding Tracks to Tidal Playlist
If I add new songs to an existing Tidal Playlist it gets added to the top (first entry) of this playlist.
Could I change this behavior to be added at the bottom (last song of playlist)?
If not, could you change the behavior with an upcoming update?
@monkee
The feature you requested is not currently supported.
You can change the order of songs in the playlist.
Rose device–>Rosehome–Total home–>My playlists–>Select the playlist you want to change the order of songs–>Click the 3-dot button to the right of the shuffle icon–>Edit playlist–>Edit on the right side of the screen You can change the order by holding down the three horizontal lines icon in the list.
@alessandro You see we’re not the only ones who find this annoying.
@Querner
I will forward your request to the software team.
They will review it and add it if they think it should be added.
