Make it possible in the setup setings an optiion:
after mains failure the Rs 250 starts direct to the
standby mode.
Is there any way to simply have RS250 ‘return
to last power state’? If not, can this capability
be added as an update?
Currently, we do not have a function to go to the display you were using by pressing the power button from the standby mode.
After checking whether it is possible to add it, we will add it if possible.
