When use AirPlay too stream music the volume is too low.
Even max is not loud and it dists.
When play Spotify using Connect the Eq doesnt work.
How can i listen too Spotify and use eq?
Let me answer to your questions
In this regard, we are currently preparing two improvements.
1-1. This is an option to fix the volume value of the source when using Airplay.
1-2. Volume setting for each source
When the features are ready, it will be applied and distributed as an update.
Was anything ever done to fix this? Ideally it’d be 1-1 on this as a fix. Other airplay speakers work this way and I find it much cleaner as solution.
