I see an issue described in this video I made: Rose 150b bugs - Google Drive
Basically, when you airplay content from my iPad Pro to Rose 150b, the volume sets itself to very low (i.e. 19). I then manually turn it up to desired output level. When I stop playback from iPad, then restart playback (same track or a different track) the volume goes back down to 19.
I believe the volume should stay at same level initially set?
thanks
