Hi, why dosent the album cover apear on display on default when I’m playing Tidal. I have to go up and press on the screen? On rose app I can choose vu meters but not back to album cover?? Br johan
If you want to see the screen where the album cover is displayed by playing music, press the screen and the available method is correct.
To remove the Vu meter in Vu meter mode in the RoseConnect app, please follow the steps below.
RoseConnectapp–> Music playback screen–> Select remote control button on the upper right–>Vu Mode–>Vu Mode Off and press the OK button.
Is there any way to have the app go back to the album art screen instead of pressing the screen physically?
Currently, there is no other way than to enable the album art screen by touching the screen.
Thanks for your reply, may I put in this as a future feature request?
Yes please do, br johan
