Alternative to WifI/BT dongle
As i begin to learn a about all the wonderful things my HiFi Rose the more disappointed I am on the implementation of using little dongles to be able to use both Wifi and Bluetooth. I am unable to add up the hours most of which were due to an external antenna-“. If I bump the RS520 ever so gently the plug in antenna wiggles loose time after time. Is there any other way to add Wi F i and Bluetooth on my 5:0?
Hey Randy’s,
1: stop bumping the unit hahaha
2: I would use a little white silicone plumbing tape on the threads of the wifi dongle to make it tighter.
Take care. Gregory
@Randyps
Contact your distributor in the country where you purchased your Rose device and request a new dongle.
