While pressing the “Watch” button on my Rose 150 B remote, I can toggle through various Clock/Display options. Of interest is the dark one with the analog clock dial. I’m able to select and view this clock/display. When I put my 150B into Standby mode, (with Always On, turned on) it shows one of six previous digital clock/display selections, not the dark one I had previously chosen. Is there any way I can toggle through my clock/display screens with my remote and then “set” that clock display to show when in Standby Mode?
It would also be great if I could adjust the brightness of the Alway On Display.
The last question, if I leave the display on showing the clock, will I risk Display burn-in
Hello @Joe
I’m sorry to tell you that you cannot link or change the clock list displayed when you press the watch button in the RoseConnect app and the watch list displayed in Standby mode (Always On Display).
Rose device—>Settings—>Display—>Always On Display
When your “Always On Display” is Off, your LCD will turn off when you set to standby mode.
When your “Always On Display” is On, your LCD will stay on and show clock display when you set to standby mode.
In Standby mode, if your LCD is off, it may burn in compared to when it is on, but there will be no big difference.
