I have my rs130 ‘always on’/clock display at the lowest setting possible (I believe it’s zero), and it’s still a bit too bright for me. Is there another way to make the always on display dimmer?
Even if you change the AOD to 0 in RS130–>Settings–>Display–>Display Brightness, we cannot help you if the screen brightness is bright.
It would be nice if you could expand the lower setting in a future update….is that possible?
We will review internally, modify the feature if we feel it is necessary, and distribute updates at a later date.
Display Brightness is too bright at lowest setting. Please update app.
Thank you for your positive advice.
Currently, we are prioritizing software stabilization.
We will also forward your suggestions to the software team.
They will check and add more if they are available.
