Lately I’ve noticed the following problem: When I turn on the RS250, the volume is low and it doesn’t sound clean. I then restart or reset the analog output voltage to my desired 1000mV in the settings. After that everything works as it should again.
But that can’t be the long-term solution, can it?
I got the same problem after software upgrade, need to restart every time.
Dear users
We applied the 4.6.07 version after resolving the symptom, but it seems that we need to check it again and update it.
We will fix it and apply it as soon as possible.
