I am wondering if others see the same behavior on the RS150. I have my analog output set to fixed (300mv), but if I switch to a digital output and then back to analog, the analog output is no longer fixed, but switched itself to variable. It seems that the other output settings remain as previously configured.
I checked your issue and I will fix it.
Awesome, thank you so much for your response.
