@Ben
Let me summarize your symptoms again.
Does this mean that if you leave your Nokia phone for a moment and turn it on again while the RoseConnect app is connected to RS520, not your Nokia, Nokia will be registered as a connected device in the RoseConnect app?
If the above is correct, please answer the questions below.
When your RS520 is registered in the RoseConnect app and then changed to Nokia, does this symptom appear after you go to a place where your phone does not have Wi-Fi and the Wi-Fi is cut off?
If this phenomenon occurs, please tell us the frequency.
If you look at the photo you sent, RS520 is displayed in Connectable devices.
If you select RS520 and then select Complete, will the device be connected again?
