Android Rose Connect 5.7 Album sorting
What is the sorting mode set to? As you can see everything is mixed up except sorting by artist.
The albums are not sorted alphabetically or by release date.
For example, take a look how AC/DC albums are sorted.
@Basstech
If you look at the part marked in red in the photo below, can’t you see the function to sort in A-Z order?
I know what You mean but there is only sort by Artist, not by Album Artist or Album Date Release Artist.
When I put sort by Artist, albums are sorted as above.
I miss search, sort, filter by tags and multiple entries separated by a user definable separator sign like semicolon ; for example. Rose is by far not perfect to make a collection of music a pleasure.
Currently, this issue has been confirmed by us and is being corrected.
We have also confirmed that searches are limited when searching for the Artist Album name by its full name. We will fix the issue and distribute an update as soon as possible.
There is so much potential in Rose Connect to improve the UI experience. Sorting is important but also the filtering option. Having more rich filtering option will be hugely beneficial to ppl who owns many albums.
@jmpsmash
Thanks for your advice.
It is difficult to add new features at the moment.
I will consider your advice in the future.
@ROSEHAN Thanks for the reply. Hifirose makes excellent hardware. However, I’d suggest the company allocate more resources on the software as that’d really maximize the potential of the hardware.
Hello! Has this issue been corrected at all? It’s been at least a year or more since this had made the app a real nightmare to use. If it has not been fixed, do you know when it will be?
Esteban,
None of this split between the hardware and software makes any sense until you understand that HiFi Rose designs and builds its own hardware - and does an excellent job of it - but it subcontracts its software development. Then you can appreciate the problem.
None of the software issues will get permanently fixed until that error (IMHO) is resolved.
Thank you. I feared as much. Which is why I may sell mine and start to look elsewhere. The hardware is great, but this is a moot point without solid software.
@Esteban
I have forwarded this matter once again to our software team.
We will review it internally and look into it more closely.
Thank you! It has been a huge problem, if I am honest. I hope it can be fixed soon. I am sure I am not alone.
