The Rose Connect App > Setting > Device Management crashes the app
The app crashes every time it is minimized.
Next when it return from minimized it’s open in main Window “Explore” not where it was minimized.
I have forwarded your content to the software team. They will check the contents and make changes.
When you say that the app crashes when you minimize it, does minimizing the app mean when you exit the app?
When you close the RoseConnect app and re-enter the RoseConnect app, it is normal to see the first screen. When we re-enter the RoseConnect app, we cannot save the previously used page.
Would you update the Rose Connect APP and try again?
Android phone > Play Store > Rose Connect Premium > Update
Hello Roseloa
the error i have reported above is gone.
The app does not crash after the latest update.
