I have the same problem. Rose Audio has recognized the problem and will work on a solution and distribute an update soon, I hope. I’m confident.
@ROSEHAN Hello. Today’s update solved the crashing problem. Thank you. Please fix the DB scan mechanism to delete from library the deleted files
The error has now been fixed with a new update. Many thanks to the Rose Audio Team. The update was very quick this time.
Do you also use Qobuz?
The app still crashes when you scroll through several albums or tracks (about 100 or more tracks) in the Qobuz view and the screen goes black in the meantime or the app is put into the background.
Yes, I used Qobuz. I didn’t notice the error you mentioned until now. I listened to music with the app and Qobuz yesterday and everything worked perfectly. I’ll check to see if I can reproduce the error you mentioned at the weekend.
Guten Tag
Ich kann den von Ihnen beschriebenen Fehler nicht nachstellen, bei mir funktioniert soweit alles korrekt.
Grüsse, M
Guten Abend @Matterhorn,
vielen Dank für Ihre Mühen!
Dass die App sich im Hintergrund schließt, habe ich sowohl bei meinem Tablet mit Android 13, also auch bei meinem Smartphone mit Android 14.
Nun werde ich mal ein Screensvideo machen und hier verlinken.
Mal schauen, was das Problem ist.
Viele Grüße
Philipp
Hello @ROSEHAN,
I have a screen video where you can see the app closing in the background:
In addition, the following error message appears every few days:
"Rose Hifi is repeatedly terminated
App Information
Close the app"
This problem occurs on both my Samsung tablet with Android 13 and my Samsung smartphone with Android 14.
Thanks!
After update everything is OK.
Please solve the problem with sort of album artists.
Regards
This issue is currently being resolved.
We will fix it and distribute updates as soon as possible.
