I just install RoseConnect on my wife’s lovely 2017 Macbook Air.
You can see my attached photo here
The annoying warning welcome notice is there and due to some reason (screen? resolution?) I can not click anything to dismiss it.
So basically I am stuck by this warning welcome notice.
Anyone know how to solve this issue?
Does the pop up message appears when you turn on the ROSE CONNECT PREMIUM for MAC?
Can you tell me if it turns off when I press esc key?
We apologize for any inconvenience.
Yes esc key solves the problem.
Thank you for prompt reply.
Well Done, Rose Team.
I have another issue but I think I’d better use another subject.
Thanks also for the question and the answer, I had the same problem
