Bonjour, j’utilise ici deezer et Qobuz est-il possible d’intégrer deezer au rs150 ?
Qobuz assis dans le canapé et deezer avec son flow quand j’écoute de loin
We also plan to add Deezer, but there is no exact schedule yet.
If possible, please move to TIDAL or QOBUZ and use it.
j’ai déjà qobuz et deezer hâte de pouvoir utiliser deezer directement depuis le rs150 :clin d’œil:
hi there
please telle me there will be an update on the rose rs150 ro add native deezet as it will be possible on the 151
since you released the 151 it should be possible to add it to the 150
thx in advance to reply positively on this important subject
rgds
ben
All Hi-Fi Rose products including RS151 do not support Deezer.
We tried to add Deezer before, but there was no response from Deezer at some point.
I will check with the software team again to see if they can add Deezer.
Dear rosehan
tjank you so much for your feedback
thats what i like with you ar rose hifi you alwayss listen to your community
regarding t deezer ând the 151 i read that since it was on android 12 you could add the deezer app… it must be wrong if you say so
thanks again
have à good day
ben
dear rosehan
did you talk to the software team to add deezet on your products?
thanks and have a gréât week end
ben
I got a reply from the software team leader.
There are currently no further plans for Dezzer, and we plan to stabilize and add more from other days.
thanks for the reply
what does it means ??
rgds
ben
@Benji
We are not in a position to add Deezer at the moment.
We will prioritize software stabilization at this time.
dear Rosehan
can you ask you développer s t eam to co.tact again deezet bécasse i ask them the question about yout products and brand and they told me they Nevers got in touch with rose hifi
it would be a major upgrade for your users and customers …
thx for your time and reply
benji
??? come on on guys we are talking about deezer … not some cheap streaming service … speaking of that you put apple music on the software…same quality than deezer
We also want to add various music streaming apps.
However, we cannot add all the music streaming apps that you want.
We are aware of Deezer. However, we are not in a position to add Deezer at the moment.
no eq no deezer … a 4500 eur unit Côme on
even eversolo has all that àt half the price . wake up guys !! you might tjink you are giving thé " best " sound out of this unit but if you listen to some chinese brand wiim eversolo etc you migjt have some réal surprises…
deezer is one of the most popular streaming company in the world and the eq is to correct the problems of the listenninc room ( all the customers dont have à specific liqtenning room at home .
please make some action and correct those 2 pb
rgds
benji
The RS151 model does not have a built-in EQ (Equalizer) function.
EQ features are mainly available on higher-end models, and the RS151 does not offer separate tone adjustment options.
thanks for your reply
but regarding à complété eq fonction i am talking about the rs 150 not the 150b or 151
deezer and a complete eq are a must have
we are many users asking those fonctions
please do Omething otherwise i will. have to sell it for another streamer .
rgds
Sorry, nothing about you. I use this thread to help everyone in the same situation.
I’ll never understand peoples who bought devices, then realises (or not) they made a mistake, thinks because they paid lot of money companie will corrected it for free, in no time. And, when that companie responds otherwise, peoples thinks by bulling with ‘I will sold my device’, add pressure on them. Soo laughable.
You’re right, other companies have products, less expensive, good sounding and with more functionalities that many crave for. Maybe Rose should do something about that, it’s ok to ask them.
If those functionalities are a real must for you, not for all customers, probably not for Rose… Why have you buy a Rose device ?
Now that you know what you did’nt know, don’t make the same mistake twice. Do your home works, sell your Rose device, buy a Wiim or anything else that ticks all your boxes. I suggest you to use the extra money to add good music to your library and Enjoy!
But, please, stop complaining about functionalities Rose never advertised for.
Isn’t the RS151 a high-end model? It’s supposed to be the new model that replaces the 150B. Is the RS151 less quality than the RS150B? I don’t understand.
Also, there is no EQ on the RS150B. Why do you say there is an EQ?
thanks,
Fred
We’re sorry, but there are currently no updates adding EQ support for the RS151 and RS150B models.
It is correct that the RS150B does not include an EQ function.
High-end models such as the RS151 and RS150B are designed without EQ support.
