Audio Analog setting causes Rose Player to crash
Hello, what can I do to access my settings for the analog output on the Rose 250A device?
If I press the gear settings menu on the Rose Display, the player crashes: restart
I have had this problem for a very long time and have waited an extra long time to report it here.
The same thing happens in the Rose app via Android on an S24 with the latest Rose app: complete crash, request for cache cleaning.
All updates up to date, all apps up to date.
I had the same problem with my RS250A, I had to reset the unit. After that, It was never a problem again.
@Rose250A
Please let me know if the same symptom appears after resetting your RS250a.
RS250a–>Setting–>System settings–>Factory reset
