Audio control on Coax output
is it possible to control the audio output via the coax output? attempting to run the Rose 250 through a peachtree GAN1amplifier.
@jtonero
Connecting RS250 and peachtree GAN1amplifier coaxially and controlling the volume on peachtree GAN1amplifier seems to be no problem.
Typical, unhelpful response, if however the manuals were more useful one would not have to figure this out without direction. And it only took mods 8 days to respond.
the useful response: each output requires separate configuration on the input/output page of the clunky software. Choose the I/O, then select the gear icon for the require I/O and you have additional configurations items that need to be selected on the following page.
For the Coax output to have control over the volume control, you need to activate this option
