Audiophile Solder
I think about changing the solder in my Rs150 AKM to a more musical one. Anyone did it before?
Wich solder will be best sounding Solder | HIFICollective.
Epic task but someone has to try it
and I thought I had heard it all…
I take @Andre being a tad sarcastic.
Man, I’m just as crazy as you, I’ve done a lot of comparisons between solder alloys. Go to Audio Note solder and then write to me. Good luck!
If power cables make a sonic difference, then solder must have the same effect :wink:
Silver solder 95.6Sn3.5Ag0.9Cu , just like 63/37 tin/lead, is eutectic. And that is very desirable when soldering.
I have 4 vintage Revox/Studer devices awaiting a complete restauration, so no one worry about me resoldering my RS150 :smiley:
Andre,
Did you use leaded solder in a closed room w no air flow?
ventilation with flex pipe to outside of building.
Don’t forget to use lots of S39
:man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2::man_facepalming:t2:
ATM i prefer to use Mechanic M35 nano flux.
