Since the current firmware (5.9.07) I’ve a problem in using the Roon auto standby.
Standby settings in the RS150 are disabled and also the “always on display”.
Standby settings in Roon are set to 5 minutes and after this time (after stopping playing music) the RS150 goes into standby.
But if I start later again playing music with Roon, it starts playing, but display doesn’t wake up (black). Also trying to enable LCD with the remote doesn’t works (becomes more grey than black, but no icons).
Only restarting the system helps for getting back a functionally display.
Additional: Some minutes after Roon sets the standby, I hear again a relais action from the RS150 → seems to be another standby state, but again: For the RS150 I’ve disabled all standby settings and with older firmware versions I don’t had this problem.
And: After Roon sets the RS150 into standby, I can start music playing with Roon and Qobuz connect with the display off.
But if I try connect the device with the app, the app told me, that the device is in standby modus. Try to wake up the RS150 with the app fails. Also the remote isn’t able to wake up it. Only restarting helps…
Again an add: I’m using an external USB Dac and had to set “USB on” while standby.
