Hi I found out that recomended list of songs with autoplay chamged from previous versions. Now this function playimg almost the songs from the same artist instead of trying to find similar artists and songs as currently played misic. This was excellent feature to discover new music similar to selected. Is it possible to have also this option from.previous releases?
I’m sorry about the issue.
Would you tell me one of the contents you played?
For example - the last song in my queue was… Coldplay - Viva la Vida in Qobuz… maybe?
Thank you,
I will try explain. I’m using TIDAL and when last played song is e.g. Yello - Till tomorrow Autoplay starts to.play only songs from yello and in previous releases it finded also other artists similar to yello and similar to track.
Hope it is clear.
Thank you for your report, I got what you mean.
I will check about it.
