Balance adjustment
Hello, I am using an RS150B connected to an RA280. Unfortunately, with this combination, it is not possible to adjust the speaker balance. Would it be possible to add a balance control feature to the RS150B via a software update? Thank you.
@jilk
Thank you for using the RS150B together with the RA280.
After checking your inquiry regarding the speaker balance control feature, we found that the RS150B currently does not support left/right balance adjustment.
However, we will forward your suggestion to our software development team for review and consideration in future updates.
Please note that we cannot guarantee that this feature will be added. After review, if there are technical limitations or development difficulties, it may not be possible to implement the feature. We kindly ask for your understanding.
Thank you for your valuable feedback.
