I am pairing a Rose 150B with a gryphon diablo 300. Was wondering what is correct voltage choice (between 100mV to 6500mV) as I’m using the rose a streamer
@Alkayoumi
Hello
I checked the input sensitivity of my gryphon diablo 300 integrated amplifier and it was 0.617V. Converting 0.617V to mV is 617mV.
When setting a fixed value from the Pre-out level setting, set it according to the input sensitivity of the amplifier you are using. First, set it to 1000mV and use it, and if clipping occurs, change it to 500mV and use it.
Thank you so much. That was helpful
I have one more question.
How do I set up the hifi rose to be a streamer and DAC and bypass the pre-amp. I would like to use the gryphon’s pre amp and the 150B as a streamer/DAC through the balanced out.
Let me anwer to your question.
To be precise, the RS150B does not have a preamplifier.
The output of the DAC directly outputs the current of the op amp through voltage conversion.
The preamplifier is a function that adjusts bass, treble, etc. in the process of receiving a low signal and boosting it and transmitting it to the power amplifier.
RS150B has no hardware bass and treble control function, and outputs the current output from the DAC through the op amp.
