Balanced & Unbalanced
Hi guys
Would there be any benefit in having the option of turning off one of the Balanced / Unbalanced outputs on the RS150B?
Currently you can only turn off both at the same time.
I run Balanced to my amp and wondered if this would make any difference at all?
Regards
Barry
@BWJ1972
You have the option to turn off one of the RS150B’s balanced/unbalanced outputs. Rather than taking advantage of this part, we decided to incorporate it in the process of designing the device.
