Best type of 2tb ssd for RS201E
I was wondering what type of 2TB SSD and how many G/B’S people could recommend for use in my RS 201E
I was thinking of storing music videos, and music and was looking for the best sound quality I could get or are they all the same.
We’ve tested up to 4TB of SSD and 10TB of HDD were fine.
You have two ways to use the storage.
  1. Connect to USB port
  2. Insert into the bottom of the product
If you hope to use No.2, the thickness of SSD should be 7mm(6.8mm), 2.5 inch size and sata series.
Thank You very much appreciate your help, and I am going to insert into bottom of your product I think it is the best way for me anyway. I think your product or products are amazing, I have loved music video’s ever since I saw on MTV in the 80’s. The rose tube app is awesome I have been waiting for something like this to come along for about 30 years how brilliant.
I am using a WD Blue SATA SSD with 1TB. Reads 560 MB/s and works fine. There’s also a 2TB version available.
Wideglide
Thank you for the info on the SSD I really appreciate that.
