Bluetooth deactivates
Bluetooth deactivates after restart
When using EA, Bluetooth deactivates after restart and the only way to activate it again is by using the touchscreen. It would be good if it would stay on by default
@Lindkar
Currently we are not seeing the same symptoms as you in the EA version.
Please check a few things.
  1. What is the model name of the Rose device you are using?
  2. When Bluetooth is turned OFF after rebooting, does Wi-Fi also turn OFF?
I am using RS130.
I have not tried the WiFi as I am not using it as such but I will check that out tonight as well. It does that after a complete restart or when it is unplugged.
For some odd reason it now remembered the setting (even after unplugging) so for now it appears to work and BT is on. Many thanks if you did something.
@Lindkar
It probably appears to be a temporary error.
I’m glad the problem was resolved first.
It has happened to my RS150 B last week after an upgrade to version 1.9, after some factory reset, Bluetooth appeared again. It found all tablets and I had appaired the remote manually.
