If you use the VLC player, the remote is prelling for pause/play and so I’m not able to pause the playlist with it.
I didn’t understand your symptoms. Could you pass me a screenshot or video?
Please forward the email to eunseong96@citech.kr.
I think, you don’t understand, what “prelling” means.
If you use the remote while playing something through VLC and use here the pause button, then the remote sends at first pause and then immediately the play command. So you can’t pause the playing with the remote.
The same issue ocurres, when you try play a paused file playing.
We have identified that issue.
However, since VLC player is not an official app that we support, we cannot give you a definite answer as to whether this part can be modified.
I have forwarded the issue to the person in charge.
We will forward the contents as soon as we receive a reply.
