Bluetooth RS151
Dlaczego RS151 nie pokazuje nazwy wyszukiwanych urządzeń po BT
@LINDROS37
The Bluetooth function on the RS151 is designed differently from other Rose devices.
The RS151 does not display a list of discovered devices; instead, you need to initiate the connection from the device you want to connect to the RS151.
However, the RS151 can display the device that is currently connected via Bluetooth.
