Any chances you will implement BDMV or AVCHD container plaback or Bluray Iso files?
I really enjoy the fact that SACD Iso files work like charm, so if we could have Bluray iso File support , it would be a hugue plus for the RS150b as a videostreamer as well and could replace many Oppo player still in use with no real alternative to upgrade.
Please consider this idea.
Only my meaning:
The video features for the RS150 are very limited (for example missing chapter handling, language selection, no support for menus,…) and the missing ISO support is IMHO the smallest problem in using a Rose device as video player.
It will never make a dedicated video player obsoleted.
HI Burki,
I don’t think it’s a limitation of the RS150 , it’s probably a problem of missing code developpment.
In the Oppo the support for ISO files was also missing until some genius implemented an unofficial firmware with support for it for the lack knowledge by Oppo’s own developpers.
The Audio section of the RS150 is just fantastic ,I think they can do it but it might not be on their priority list by now until most of the other bugs will be fixed.
Let’s hope that such an expensive device gets the OS it deserves before they stop producing it
