BT Pairing RS 150B to NAD T778 Receiver
The NAD T778 receiver is recognized under paired devices but does not turn gold, unable to play Rose files on receiver, help please.
Bluetooth in ROSE devices can receive but cannot send out signal.
Thank you for your prompt response, it saves lot of time trying to pair the RS 150 with another device, can I purchase a Bluetooth usb stick that works ?, please provide model and specifications, I will wait for your response.
Changing the external USB type BT WIFI dongle will allow the RS 150B to send out signal to a paired device?, A2DPSink or AVRCP v1.3, please advise.
Even if you change the Bluetooth dongle in RS150B itself, transmission is not possible. There may be some possible models, but they are not recommended because they have not been tested and can cause various bugs.
However, as far as I know, some users connect the Bluetooth transceiver to RS150B separately and use the Bluetooth transmission function after connecting via Optical/RCA, etc.
