BUG REPORT: local audio file stuck in PAUSE
I have a reproducible bug report and video demo.
If I pause a looped (3 second long) mp3 audio file from the internal SSD drive, then pause it (from either the Rose 150b device or the Rose Premium app) you can see the following:
  • Track pauses (no sound), as expected
  • Play button briefly turns from “playing” icon to “play” icon but then quickly back to “playing” icon
  • Track progress loops as if it is playing
  • It is now not possibly to UNPause the track. You have to go to another track or re-load the original track.
Internal audio file cannot be UNPaused
Thank you very much for your detailed explanation along with the video. I will share this issue with the software team and have them check it.
Best Regards,
