BUG REPORT: Volume control stuck on iOS and iPadOS
I can report another issue on both iOS and iPadOS versions of Rose Premium Connect app in regards to a random stuck volume control by way of the ± signs.
Please video demonstrating the issue: Rose Premium Connect software Volume controls stuck
This is not reproducsible at will and only happens some of the time. Once I touch the 150b hardware or drag the software control on the app, ± control is regained.
thanks
This isn’t an issue w the RS520.
I tend to use the Rose app instead of the remote.
No problems w volume control from iOS (Mac M series) and from iPad and iPhone.
@taystnotes
We have reviewed the video you sent, and it appears that a fix may be required.
This issue has been forwarded to our software team and is currently under review.
However, since we have not been able to reproduce the problem on our side, we may need some additional time until the issue occurs again during our testing.
ok understood. I saw it again last night and will try to understand when it happens, then advise.
@taystnotes
Yes, please check it, and if the issue occurs again, let me know.
