Sorry to wake up this topic as I don’t know if @danielllo71 still has an issue replacing this part.
I had very good experience repairing my Martin-Logan ESL faulty power board tks to Gemini assistance.
So I shared your pic with it and these are the things it has to say. Take it as always with a pinch of salt (as AI is not bulletproof), and this takes as assumption you know what you’re doing
The burned component pointed to by the orange arrow is a 6-pin Synchronous Step-Down (Buck) DC-DC Converter IC in a SOT-23-6 (TSOT-23-6) package.
It operates alongside the adjacent 2R2 (2.2 µH) shielded power inductor, bootstrap capacitor C16, input capacitor C10, feedback resistor network (R1, R3, R5), and output filter capacitors (C11, C12, C1303, C1302) tied to output test point TP76. This regulator steps down the main incoming DC supply rail (typically 12V) to a low-voltage standby/system rail (5V or 3.3V) that powers the nearby U3 linear regulator and U4 system-control microcontroller. When this buck converter fails, U4 loses power and cannot trigger the main power relay or boot sequence, making the entire RS150B appear completely dead.
Schematics & Board Architecture Info
- Factory Schematics: HiFi Rose (Citech) does not release public service manuals or schematics for the RS150B; authorized service centers only perform whole-board swaps (replacing the entire CPU board or Audio board).
- Reference Architecture: The RS150B main CPU board is built around a Rockchip RK3399 platform. You can see this in the silkscreen: the core board uses 4-digit Rockchip reference schematic numbering (C1302, C1303, R1282, U1023), while HiFi Rose’s custom standby/control subcircuit around the 48-pin MCU (U4) and UART header (CN1: GND, TXD, RXD) uses 1- to 2-digit designators (R1–R5, C10–C16, U3, U4).
Component Pinout & Candidate Part Numbers
Because the crater on top of the IC obliterated the laser marking code, the exact replacement part is narrowed down by tracing the six pads on your board:
| Pin (Orientation in Photo) |
Most Likely Pinout (Rockchip / Silergy / MPS Standard) |
Alternative Pinout (TI Eco-Mode Standard) |
Connected PCB Feature JPG |
| Pin 1 (Top-Left) |
BS / BST (Bootstrap) |
GND (Ground) |
Bottom pad of C16 / Ground plane |
| Pin 2 (Middle-Left) |
GND (Ground) |
SW (Switch Node) |
Ground plane / 2R2 inductor pad |
| Pin 3 (Bottom-Left) |
FB (Feedback) |
VIN (Input Voltage) |
R1 resistor network below IC |
| Pin 4 (Bottom-Right) |
EN (Enable) |
VFB (Feedback) |
Resistor network below IC (R1/R3/R5) |
| Pin 5 (Middle-Right) |
IN / VIN (Input Supply) |
EN (Enable) |
Adjacent input capacitor C10 |
| Pin 6 (Top-Right) |
SW / LX (Switch Node) |
VBST (Bootstrap) |
Trace to 2R2 inductor & top pad of C16 |
- Primary Candidate Group (Pinout: 1:BS, 2:GND, 3:FB, 4:EN, 5:IN, 6:SW):
- Silergy SY8113BADC / SY8120B1ABC (or pin-compatible STI3470 / TCS4313B): 4.5V–18V input, 2A–3A output, 500 kHz, VFB=0.6V. This is the standard SOT-23-6 buck regulator used across Rockchip RK3399 reference designs.
- MPS MP1470GJ / MP2315GJ: Identical footprint and pinout, 4.5V–16V/24V input, 2A–3A output, VFB=0.8V.
- Secondary Candidate Group (Pinout: 1:GND, 2:SW, 3:VIN, 4:VFB, 5:EN, 6:VBST):
- Texas Instruments TPS563201DDCR (VFB=0.6V) or TPS563200DDCR (VFB=0.765V): 4.5V–17V input, 3A output.
Diagnostic & Identification Steps
Before soldering a replacement IC, you must verify that the blown chip did not short the input rail into the output rail and damage U3 or U4, and take two quick multimeter readings to lock in the exact replacement part number.
Electrical & Board Safety Warning
Always unplug the AC power cord and wait at least 5 minutes for the RS150B’s internal linear power supply capacitors to fully discharge before touching the board, probing, or desoldering components. Never power the board while the burned IC is still attached, as a shorted high-side MOSFET inside the chip can send 12V directly into the 3.3V microcontroller (U4).
1.Remove the burned IC and clean the pads:Soldering iron / hot air & 99% IPA.
Apply flux and carefully desolder the blown 6-pin IC using hot air or a fine-tip soldering iron (if you are new to surface-mount rework, watch this guide on how to desolder and solder SOT-23 SMD components). Clean the charred black residue off the PCB pads thoroughly with 99% isopropyl alcohol and a cotton swab, as carbonized plastic can be conductive.
Verification: Inspect the pads under magnification to ensure all 6 copper pads are clean, intact, and not bridged together with solder.
2.Check the output rail for a downstream short circuit:Multimeter in Resistance / Continuity mode.
Set your multimeter to resistance (). Place the black probe on CN1 Pin 1 (GND) and the red probe on test point TP76 (or the top pad of C1303).
- A healthy rail typically reads several hundred ohms to several kilohms.
- If it reads near 0 to 10 even after the burned IC is removed, a downstream component (such as output capacitors C1303/C1302, LDO U3, or MCU U4) is shorted to ground.
Verification: Confirm the resistance at TP76 to GND is well above 50 before installing any new regulator.
3.Confirm the exact Ground pin on the PCB footprint:Multimeter in Continuity mode.
Keep one probe on CN1 Pin 1 (GND) and touch the other probe to Pin 2 (Middle-Left pad) and Pin 1 (Top-Left pad) of the empty 6-pin IC footprint:
- Continuity (0) on Pin 2 (Middle-Left) confirms the Silergy SY8113BADC / MPS MP1470GJ pinout (1:BS, 2:GND, 3:FB, 4:EN, 5:IN, 6:SW).
- Continuity (0) on Pin 1 (Top-Left) confirms the TI TPS563200 / TPS563201 pinout (1:GND, 2:SW, 3:VIN, 4:VFB, 5:EN, 6:VBST).
Verification: You should get a solid continuity beep on exactly one of those two pads to GND.
4.Measure the feedback resistors to verify the reference voltage:Multimeter in Resistance mode.
Measure the resistance from the Feedback (FB) pad (Pin 3 Bottom-Left or Pin 4 Bottom-Right) to TP76 (VOUT) (Rtop), and from the FB pad to GND (Rbottom). The output voltage follows:
VOUT=VFB1+RtopRbottom
Knowing the ratio RtopRbottom tells us immediately whether the circuit is designed for a VFB=0.6V chip (SY8113BADC / TPS563201) or a VFB=0.8V chip (MP1470GJ).
Verification: Record both resistance values in kilohms (k) with the burned IC removed from the board.
Once you remove the burned chip (or even before removing it, if you have a multimeter handy), which pad on the IC footprint has continuity to GND, and what resistance do you measure between TP76 and GND?
