After last Update I Can not scan or delete my storage hdd.
When trying the app shots Down.
Please fix it quickly.
It is believed that an error occurred in a specific section during media scanning.
Please answer any additional questions.
Do you see the same symptom even after rebooting the Rose device?
Does the same symptom appear even if you do ADD DB after initializing the DB on the media library screen?
If the same problem occurs even if you add DB after DB initialization as shown above, click Remote Debug.
Rose device–>Settings–>System settings–>Remote debug
(Press Remote debug once and do not turn off the Rose device.) -
Please tell us your Rose ID.
Rose device–>Settings–>System info–>ROSE ID -
Additionally, after removing the built-in SSD, check if the same is true if you connect only one other storage device.
I think we need to check the DB log file.
