Can the community help in better translations?
I’m using a RS201E here in Germany and love the great work you have done in the hardware and software of the device. You did a reasonable good job on translating into German.
To make it even better I suggest too let us the community help you. If possible give us a CSV file with ‘English / translated language’ and we can improve the translations. The English translation look very good so I suggest too use them as base. I guess that not many Korean people speak the European languages (France, German, Dutch, Czech etc.)
I can help with Polish since there is none.
good idea, i would help
gute idee, ich würde helfen
I currently found a translation mistake in German:
Under Settings, Display the translation is currently “Bildshirm”
It should be correctly called “Bildschirm” or better “Anzeige”.
@Matterhorn
I have forwarded your request to the person in charge. It will be revised and reflected in the next update.
