The RS150B can access music files stored on a USB memory device via the USB 3.0 port in the back panel.
Will it be possible to connect a USB hub to the USB port, so that more than one USB memory disks can be read via the hub ?
You can connect a USB hub to your USB port to recognize one or more USB.
However, when using a USB hub without a charging port, recognition failure or other problems may occur if power is insufficient.
So, if there are 8 ports or charging ports among the USB hubs, there is a separate power source, and there is no problem in using it.
This is the question I previously asking for. Finally I bought a transcend hub3. 0 as recommended from other memeners with good result.
Thank you all.
Yes, it’s a good idea to use a powered hub.
BTW, will it scan for the USB disks automatically?
Yes, all USB disks are automatically scanned. If the scan did not work or the added songs are not scanned, you can perform a DB rescan in the Media Library.
Got it.
Thank you very much.
